REVIT 2017 load rvt file slow
dear expert,
kindly advice why my pc system load very slow for 65MB rvt file for REVIT 2017
system - window 10 pro
processor - AMD ryzen 1700 3.0GHZ
motherboard - GIGABYTE AB350M-D3H AM4 MATX
SSD - WD Green 240GB (main drive)
HHD - WD CAVIAR BLUE 1TB (2nd Drive)
DDR4 - 32GB RAM
Thermaltake 750W GOLD - PSU
GPU- GTX1080TI.
I have no idea why i load a 65MB file will take for 5-10mint long. Even after finish load its seem very slow when need to zoom in/out.
Please help.
thanks.
ennujozlagam
@Anonymous hello, have you try to tick audit before opening the file and untick use hardware acceleration from options > graphics and see if helps. try to install latest updates from autodesk. thanks
Tried. still the same.
thanks
artejon
Have you got any files linked into your file ? Are you loading via internal network ?
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
yeah, it have quite lot of link into my archi & structure file. main link is from level04 to 44th storey then the rest of the link is typical unit and PBU toilet layout. rought might link to 15+20 link for superimpose.
i have checked with other subcon who open the same system is quite fast even in lower spect of computer system. this make me have a lot of ?????. and yes, we are loading internal network.
Revit add-ins: Purger (unused line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags), View Filter Manager at Revit Apps Store
going to try this by tomorrow.
thanks.
Viveka_CD
Hi @Anonymous
Please send us a Revit Journal file to troubleshoot.
There could be several Possible causes for slow performance in Revit ranging from graphic cards to memory to multiple model elements.
Please try the following:
  1. Check graphic card requirements and update driver from manufacturer website
  2. Please purge unused items
  3. Group the lights by room in your project and only leave on the group in the view you are working on.
  4. Make sure the machine meets minimum requirements
  5. Dock Project Browser and Properties Pallete
  6. Make sure the project is at least 20 times smaller than the memory
  7. Disable second monitor if using
  8. Set the resolution of the monitor to 100%DPI
  9. Install all the latest updates
For more information on recommendations to improve slow performance please see HERE
Let me know if you were able to resolve your issue.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos are welcome.
