Revit 2017-Graphic issues, lines dissapear while moving views and 3D
4 REPLIES 4
2995 Views, 4 Replies
I have never had any issues with Revit 2016 but recently I tried out Revit 2017 and when I move views or the 3D lines and hatchs, dissapear.
I have already uninstalled and reinstalled Revit 2017 and continues happening.
What can I do?
Thank you
4 REPLIES 4
ennujozlagam
hello, have you tried to untick " use hardware acceleration" from options > graphics and see how it goes and try to update your graphics card driver to the latest. thanks
in reply to: ennujozlagam
It continues the same, I have been working with revit 2017 on Friday without any trouble but today isn´t working properly.
In revit 2016 I don`t have problems even with the graphics aceleration enabled and the drivers are updated.
Thank you
chrisplyler
What happens if you uncheck the options for Draw visible elements only and Allow navigation during redraw? Uncheck each of those in turn and see if either of them has an effect.
in reply to: chrisplyler
FOUND IT IN ANOTHER FORUM!!!
http://www.revitforum.org/architecture-general-revit-questions/29590-revit-2017-graphics-issue.html?...
http://www.revitforum.org/architecture-general-revit-questions/29563-optimized-view-navigation-bdsp-...
And it WORKS!!
I copy the solution below:
Optimized view navigation in BDSP 2017
Last year i had a problem that i could not turn off optimize view navigation in Revit LT 2016.
Revit LT 2016, Optimized View Navigation
I solved the problem by adding OptimizedViewNavigation=0 to the Revit.ini .
I tried the same thing now in 2017 full version but it does not fix my problem.
I also tried using the 2016 revit.ini for 2017 but the problem still exists.
I later found that the option OptmizedViewNavigation was replaced with AllowNavigationDuringRedraw in Revit 2016.
I tried adjusting it, but that also didn't fix my problem.
LOL, i was editing the Revit.ini in the Pogram data folder instead of the one in the users folder it all works perfect now.
The solution was to add OptimizedViewNavigation=0 to the [Graphics] part.
