Revit 2017.1 crashes on startup
dm.bulakh
dm.bulakh
I installed Revit 2017.1 and it crashes on startup, with error below.
' 1:< ::0:: Delta VM: Avail 134216513 MB, Used 168 MB; RAM: Avail +17 -> 1394 MB, Used +0 -> 276 MB, Peak +0 -> 276 MB
' 1:< GUI Resource Usage GDI: Avail 9835, Used 165, User: Used 161
' 1:< DBG_WARN: failed to create message_queue named 'Session7888_P0MasterQueue' because boost::interprocess_exception::library_error: line 203 of NOBLE\ManageWorkerServices.cpp.
' 1:< Exception occurred
'C 14-Nov-2016 01:27:04.836; 1:< ExceptionCode=0xc0000005 ExceptionFlags=0x00000000 ExceptionAddress=00007FFA96F136BB
' 1:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ]
' 1:< RAM Statistics: 1392 / 6068 276=InUse 276=Peak
' 1:< VM Statistics: 134216513 / 134217727 168=InUse 168=Peak
' 2.051538!!! 2:!!!BIG_GAP Initializing Slave Process
Other Autodesk Software (AutoCAD 2017, Inventor, Revit 2016) works properly.
Windows 10.
ennujozlagam
@dm.bulakh hello, try to install latest updates and service packs from autodesk, check HERE and see if helps.
dm.bulakh
I've tried but it didn't solve the problem.
ennujozlagam
Hello, can you please post your computer specs. it could be have an issue with your computer. you can check it HERE if your compter meets the requirements to run Revit 2017 in your computer. thanks
dm.bulakh
Windows 10 Pro 64-bit
Intel Core i5 4200M CPU @ 2.50GHz (4CPUs)
6144MB RAM
NVIDIA GeForce GT 740M
