Revit 2016
Revit 2016
Revit 2016
Hello. I am unable to open the material browser when changing a material type. I click the three dots and nothing opens. I have reinstalled the libraries and reinstalled revit but still nothing. Any other thoughts or ideas?
Giosue.Garita
My name is Giosuè, I am a Revit specialist.
This issue may occur due to corruption on the Microsoft .Net Framework Language and we may have to correct it.
To correct the Microsoft .Net Framework component, please navigate to the Control Panel within Windows, to then run a repair to .Net and restart your system.
Steps:
-Open Control Panel.
-Click on “Programs”.
-Click on “Programs and Features”.
-Select the Microsoft .Net Framework from the list <double click it>.
-Repair the .Net Framework.
-Restart your system and launch Revit to confirm resolution.
I hope this helps.
Cordiali saluti / Kind regards
Giosuè Garita
Autodesk, Inc.
Giosue.Garita
You may also want to make sure that your graphics card is certified in our internal webpage HERE (adjust according to your system configuration).
In addition, you can also refer to the article HERE.
Giosuè Garita
Autodesk, Inc.
