Revit 2016 - unable to open file
I tried renaming a level in an elevation view and the program shut down with pop-up boxes saying,"Unable to open because of unresolved pointer references. Please contact Autodesk Support." When I try to open the file it does not let me. What can I do to recover the file? I need it ASAP!!!
Why are you opening backups? Is your file so bad you had to go back 50 of them?
Rename your file to MaggiesCenter.rvt  and run an audit.  It opens just fine for me.
