Revit (2016) Line Changes Type When it Exceeds a Given Length
A Revit detail line (Solid #6 width) is solid until it gets longer than 101' 11".  At 102' or longer, it changes to a Center Line Type!  When it is shortened to less than 102' it returns to a solid line.
Any thoughts?
Replies (10)
David_Knight
what happens if you change scale?
what line style is applied to that object type?
Is that object being overridden in the view? (vg or template)
i wonder if there is a line type applied, but due to the scale it happens to change to continuous since it is too short for that view?
1. It's happening on a site plan, so the scale is 1" = 30'
If scale is changed, same results at different lengths. (At 1" = 40' the line has to be longer to change type, but still does)
2. It's just a detail line.  It's solid, #6 wide.
3. No Overrides or View Templates
David_Knight
go to:
Manage -> Additional Settings -> Line Styles
Expand the window, what is the name of the line pattern used for "#6 wide"
I suspect its not "continuous"
That "solid" Line Style definitely not uses the Continuous line pattern.
"Wide" Lines has a Pattern = Solid
It is #5
David_Knight
is "Wide" the like type you are having issues with?
if so, i would need to see a test file to troubleshoot from here.
Otherwise you can check this too:
Check VG (or your template) under:
Model Categories -> Lines -> make sure that "wide" does not have an override applied.
also, i used the word "continuous" earlier when i should have used solid.  Sorry for any confusion on that.
Line pattern names mean little to nothing.  Edit the Line Pattern definitions and see what the line pattern "solid" defined.
David_Knight
Ohhhh yeah. I hadnt worked the problem that far yet.  You're probably right.
The "Wide" #5 line is a Revit standard issue, I created the #6 solid line (along with 5, 4, 3, and 2) for various uses.
It was created, as a new sub-catagory in the Manage > Additional Settings >  Line Styles dialog window.
Someone entered an override in the VG Lines!
AAAARRRGGGHHH
Thank you for your help!
David_Knight
ah ha! i was right!
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
