I have windows 10 download on my Mac through bootcamp and I have revit and auto cad downloaded onto the windows side. When I use revit, it works fine for a little bit and then randomly will start freezing and not processing anything. It doesn't let me save the project I was working on and doesn't let me quit out of it to the point where I have to end the task via Ctl alt delete. Is there anyway to fix this? Did revit install incorrectly on my computer? What can I do to make the freezing stop?
Solved by yurikim. Go to Solution.
Thank you for your posting @Anonymous
Please refer to the system requirements, Revit 2016 isn't supproted in Windows 10.
You can try to install 2017 or 2018 and see if this works.
@Anonymous hello, open revit, go to options > graphics > untick use hardware accelerations, install latest updates from autodesk, updates graphics card driver and see if helps. thanks
