Revit 2016 Error
Revit 2016 Error
Revit 2016 Error
As I continue to add to my Revit File, I keep getting these prisms. I recently downloaded the student version of Revit 2016. I'm using VMware to run this on my mac book pro (2015). Does anyone know what is happening or how I can fix the problem? The error is also occuring on my plans.
GHASEM_ARIYANI
hi
Be sure to update your graphics card.
or
in the option>Graphic tab > uncheck Use Hardware Acceleration.
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Does this happen in all models or only this one? If it only happens in this one model, how far is the model from the Revit model origin?
Anssi
I unchecked Use Hardware Acceleration . Thank you!
BIMologist_
If that fixed your issue please mark the original reply as a solution.
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
2015/10/26:09:52:42 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2015/10/26:09:52:42 user WS_MF_0011 Path_Length: 155
2015/10/26:09:52:42 user WS_MF_0011 Current Directory C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm
2015/10/26:09:52:42 user WS_MF_0011 Launch
2015/10/26:09:52:42 user WS_MF_0011 CommandLine
2015/10/26:09:52:42 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI79E1.tmp
2015/10/26:09:52:47 user WS_MF_0011 === Setup ended ===
2015/10/26:09:52:44 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2015/10/26:09:52:44 user WS_MF_0011 Path_Length: 155
2015/10/26:09:52:44 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI79E1.tmp
2015/10/26:09:52:44 user WS_MF_0011 Launch
2015/10/26:09:52:45 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI79E1.tmp\Setup\RevitSetup.dll
2015/10/26:09:52:45 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/10/26:09:52:46 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI79E1.tmp\Setup\RevitSetup.dll
2015/10/26:09:52:46 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® MEP 2016. URLTitle= URLLink=
2015/10/26:09:52:47 user WS_MF_0011 PageOpen LaunchDialog
2015/10/26:09:52:49 user WS_MF_0011 PageOpen LicenseDialog
2015/10/26:09:52:51 user WS_MF_0011 PageOpen ProductInfoDialog
2015/10/26:09:53:13 user WS_MF_0011 PageOpen ProductSelectionDialog2
2015/10/26:09:53:14 user WS_MF_0011 PageOpen FullProgressDialog
2015/10/26:09:53:14 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/26:09:53:19 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2015/10/26:09:53:19 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/10/26:09:53:22 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2015/10/26:09:53:22 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/26:09:53:33 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2015/10/26:09:53:33 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2015/10/26:09:53:33 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2015/10/26:09:53:34 user WS_MF_0011 PageOpen InstallCompleteDialog
2015/10/26:09:53:51 user WS_MF_0011 === Setup ended ===
2015/10/26:12:22:19 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2015/10/26:12:22:19 user WS_MF_0011 Path_Length: 155
2015/10/26:12:22:19 user WS_MF_0011 Current Directory D:\kareem\SCS BACKUP\KAREEM\revit 2016\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm
2015/10/26:12:22:19 user WS_MF_0011 Launch
2015/10/26:12:22:19 user WS_MF_0011 CommandLine
2015/10/26:12:22:19 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI7274.tmp
2015/10/26:12:22:23 user WS_MF_0011 === Setup ended ===
2015/10/26:12:22:20 user WS_MF_0011 === Setup started on WS_MF_0011 by user ===
2015/10/26:12:22:20 user WS_MF_0011 Path_Length: 155
2015/10/26:12:22:20 user WS_MF_0011 Current Directory C:\Users\user\AppData\Local\Temp\_AI7274.tmp
2015/10/26:12:22:20 user WS_MF_0011 Launch
2015/10/26:12:22:21 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI7274.tmp\Setup\RevitSetup.dll
2015/10/26:12:22:21 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/10/26:12:22:23 user WS_MF_0011 Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\user\AppData\Local\Temp\_AI7274.tmp\Setup\RevitSetup.dll
2015/10/26:12:22:23 user WS_MF_0011 Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® MEP 2016. URLTitle= URLLink=
2015/10/26:12:22:23 user WS_MF_0011 PageOpen LaunchDialog
2015/10/26:12:22:25 user WS_MF_0011 PageOpen LicenseDialog
2015/10/26:12:22:29 user WS_MF_0011 PageOpen ProductInfoDialog
2015/10/26:12:22:52 user WS_MF_0011 PageOpen ProductSelectionDialog2
2015/10/26:12:22:54 user WS_MF_0011 PageOpen FullProgressDialog
2015/10/26:12:22:54 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2016\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/26:12:22:57 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2015/10/26:12:22:57 user WS_MF_0011 Installing Microsoft Visual C++ 2005 Redistributable (x64): "D:\kareem\SCS BACKUP\KAREEM\revit 2016\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x64_2005.log"" "
2015/10/26:12:23:00 user WS_MF_0011 Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2015/10/26:12:23:00 user WS_MF_0011 Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "D:\kareem\SCS BACKUP\KAREEM\revit 2016\Autodesk_Revit_MEP_2016_English_Win_64bit_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\user\AppData\Local\Temp\vcredist_x86_2005.log"" "
2015/10/26:12:23:12 user WS_MF_0011 Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
2015/10/26:12:23:12 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2015/10/26:12:23:12 user WS_MF_0011 Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
