Revit 2016 error: an unnamed file contains an incorrect path
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
I have been looking through the forums about this error and so far all I can find is related to systems or assemblies, however I have been getting this same error when I try to sync to central.
Some background: I am working on a large project and currently we have about 20 models all linked into each other. We are using Revit 2016 and we have all of our Revit models hosted on Revit server.
Currently each model has its own specific sheets and then the models are all linked into our SHEET model which is used to produce the cover page and drawing index sheet for each package of drawings.
Recently, I have been getting this error message quite a lot when I try to sync this sheet model. I update the linked files, reload them, and then when I sync, I get the error. It doesn't happen often, but recently it has happened twice within the span of 4 days.
The workaround that I have been doing is to save the local file and close it, then reopen with Audit checked - when I try to open it detached I get the same error. Then I have to "save as" and give it a different name. Close the file, open it again, this time detached (as it allows me to) and then I can save over the original file.
Has anyone else seen this happen when trying to sync and how have you resolved it? Does anyone know what causes this error to appear?
Any feedback would be greatly appreciated.
Many thanks.
