Revit 2016 Does not respond after startup screen
Hi
I'm having the problem that after starting Revit the start-up screen pops up.
When this one closes the homescreen of revit appears and I get the "Revit is not responding" message, no error report appears.
I'm running Revit 2016 on a Asus laptop (8gb RAM Nvidia Geforce 740M)
Is there anyone who can help me? Revit 2017 does the same
Thank you for your time
S.Jebakumar
Hi @Anonymous,
This may be due to licensing issue try to follow as directed in the link.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-splash-screen-starts-up-and-then-closes.html
Jebakumar
BIM Specialist
He @S.Jebakumar,
Thank you for your time, sadly it's not working.
I opend the ADLM File and this appeard:
2140 2016/12/22 08:35:48 Reason=Fatal error
2140 2016/12/22 08:35:48 ComputerName=DESKTOP-I430704
2140 2016/12/22 08:35:48 OS=6.2.9200.
2140 2016/12/22 08:35:48 File=AdlmIntSessionHandle.cpp,Line=377
2140 2016/12/22 08:35:48 AdlmIntError=17 [The license was not found]
2140 2016/12/22 08:35:48 File=AdlmIntLicenseMgr.cpp,Line=1735
2140 2016/12/22 08:35:48 AdlmIntError=14 [ADLM session handle not found]
The splash screen is closing and the normal home screen of revit pops up (where u can chose projects, families etc.).
After a few seconds there is a pop-up from windows and the "Autosdest Revit is not responding" appears.
Bart Hazewinkel
S.Jebakumar
Hi @Anonymous,
Probably this is due to malfunctioned upgrade in windows or service pack.
Try follwing the link
http://blogs.rand.com/support/2014/09/resetting-autodesk-standalone-licenses.html
or
Please seek assistance from local Autodesk Reseller or Autodesk Support team.
Jebakumar
BIM Specialist
@S.Jebakumar
Thank you for your time, sadly those sollutions didn't work for me.
I decided to use 2015, this one works perfect.
Thank you!
