Revit 2015 on macbook with windows 8.1 or windows7
Hallo ,
i am student and i have macbook 13 .
i have installed Revit 2015 on my mac with windows 8.1 but the programm is going very slow
and i did what  some advised  me about the Hardware acceleration or the Display
so my question : is the programm will  work  better with windows 7 than 8.1
thanks and nice weekend
To my knowledge there is no such thing as a "Macbook 13". If you are referring to the size of the screen (13"), then we would need to know the model year of the Macbook, to know which mac you are running.
To my knowledge, there is no preference for Revit 2015 when it comes to Windows 7 or Windows 8.1 - although generally speaking Windows 7 is known to have better performance than Windows 8.1 - which might in turn also impact Revit.
And from one mac user to another, let me just tell you that running Revit on a mac is generally just not an optimal solution. Even though you might get it to work (which i did as well), you will experience weird issues which boils down to the hardware / software on a mac just not being optimized for running Windows. Graphics drivers are often released with an immense delay for Bootcamp too, which means that even known issues might exist on your mac for months (or years) even after they are fixed.
Good news is that being a Revit compatible Windows PC is not that big of an investment and is quickly "made back" in terms of just having compatible hardware/software that don't cost working hours.
Thanks for answering my question.
i have macbook  13 pro 2015
  Prozessor 2,7 GHz Intel Core i5
  Speicher  8 GB 1867 MHz
 Grafikkarte :Intel Iris Graphics 6100 1536 MB
i know that is not the  good  one for Grafik but as student and learn and practice that what i could have .:)
maybe i should Install also the updates of Revit 2015 ?.
Updating your software (latest bootcamp drivers and Revit version) is always a good idea.
Also i'm curious to know what you mean by "Revit running slow".
Hardware-wise your Mac should not have any issues running Revit 2015 comfortably, so if you experience issues during normal work with Revit, you most likely have some compability issue.
Are you running a 4K resolution? Revit 2015 have known issues with resolutions higher than 1920x1080, so if you run anything higher than that, i would decrease the resolution to that when working with Revit.
