Revit 2014 Thin Lines mode affecting printing
BobbyC.Jones
Message 1 of 20
BobbyC.Jones
Is anyone else experiencing the Thin Lines mode printing with thin lines, not just affecting the view display?
Bobby C. Jones
Replies (19)
Message 2 of 20
constantin.stroescu
it would be a method:
  • select the view you want to print with thin lines
  • from Properties >RC > Duplicate View > Duplicate with Detailing
  • in the new created view select all (cross selection) > View > Override Graphics in View > Override by Element >View Specific Element Graphics > change Projection Lines and Cut Lines to 1
  • Don't print at a scale higher that the scale of the view...
Constantin Stroescu
Message 3 of 20
constantin.stroescu
Print > Vector Processing
Constantin Stroescu
Message 4 of 20
BobbyC.Jones
What I mean is Revit 2014 is doing something that I've never seen any version of Revit do before.  When the Thin Lines mode is toggled on it is not only displaying all lines as thin lines, it's also printing them that way.  If I can't get this figured out we're going to go through a lot of paper!
Bobby C. Jones
Message 5 of 20
BobbyC.Jones
And to make it more interesting, it prints normally to DWF; it's only hardcopy prints that are affected.
Bobby C. Jones
Message 6 of 20
I'm not seeing that here, I don't know what would cause thin lines to print as displayed other than printscreen
Message 7 of 20
Oh wow....yeah, I see what your talking about...
Message 8 of 20
BobbyC.Jones
Are those scans of hardcopies?  That's exactly what I'm seeing  😞
Bobby C. Jones
Message 9 of 20
They are prints to PDF and I just did a couple of snips from the pdf...
Message 10 of 20
Time limit to edit a post?
Anyway...
Really this isn't that big of a deal....its just another button you have to make sure is turned off before you print...since TL isn't a view by view setting.
Message 11 of 20
Spoke too soon, I was just looking at the model walls. Annotation lines appear to be the items affected by this.
Message 12 of 20
Yeah, schedules, view titles, dimensions...etc...
Message 13 of 20
Need a hotfix for this one
Message 14 of 20
BobbyC.Jones
I concur! Hotfix STAT!
Sent from my Windows Phone
Bobby C. Jones
Message 15 of 20
Lance.Coffey
Autodesk Support
Autodesk Support
This issue has been logged with our development group, they have been able to reproduce the issue, and are actively working to fix it.
Lance Coffey
Technical Support Specialist
Message 16 of 20
BobbyC.Jones
Thanks for keeping us in the loop Lance!
Bobby C. Jones
Message 17 of 20
andymp2000
Same issue here - and as a relatively new Revit user, I thought it was me...
Message 18 of 20
Lance.Coffey
Autodesk Support
Autodesk Support
Update 1 for Revit 2014 has been released, and includes the following in the Enhancements PDF:
"Corrects visual fidelity of objects in printed output which show as “Thin Lines” in drawing canvas"
Has anyone been able to verify that the update fixes the issue for them?
Lance Coffey
Message 19 of 20
BobbyC.Jones
Confirmed!  Thanks for the followthrough and letting us know that the fix arrived Lance.
Bobby C. Jones
Message 20 of 20
m.voss.alvine
I installed SP3 for Revit 2014 and it fixed the callout line weight plotting issue.   I was hoping it would fix an additional issue we were encountering.  The architect is using a filled region to mark a designated area.  In our MEP model, this designated area is turned off.  When we plot, our devices that are in that area do not plot.  The annotation associated with the device still plots.  We tried everything we could think of in visibility graphics.  The only thing we could do is delete the filled region prior to linking.
Revit MEP 2015 Certified Professional
Revit Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional
remember to 'accept as solution' if this helped
