Revit 2014 on Windows 10
I upgraded to Windows 10 from Windows 7 this morning, and my Revit 2014 is crashing when I try to open it.  Has anyone else experienced this problem?  Is there a recommended fix or patch?  I have the latest udpate version 3.  Help!
Autodesk never said Windows 10 was compatible with any of their products yet
other threads on this subject: http://forums.autodesk.com/t5/forums/searchpage/tab/message?filter=labels&q=windows+10
dgallivan
Observer
Observer
I was quite surprised after upgrading to Windows 10 on my Surface Pro 3 that Revit 2015 (UR9) opened fine.  Also tested Revit for Collaboration shared file and no issues opening that model either.  In fact most apps seem to run OK including AutoCAD 2015.
Thanks for the replies.  I used the Windows 10 option to revert back to Windows 7.  It was actually very easy, and I am releived that my Revit 2014 is working just fine again.  That's what I get for charging into an OS upgrade without researching!
rmoore3
Revit 2014 works on my Windows 10 test machine but the QAT only shows when it is below the toolbar
I got my Revit 2013 to work with the Windows 10 upgrade too.
