Revit 2014 for 32 bit
HI!
I have my PC with 32 bit system settings and when i try to download revit with education license only revit 2015 to onward are available and only for 64 bit. what to do?
ennujozlagam
@Anonymous hello, you can download from autodesk virtual agent for Revit 2014 32 bit <click HERE>> . thanks
@Anonymous wrote:
HI!
You will need to contact the Education Community Support... https://www.autodesk.com/education/support/edu-contact-us-form
Or get a newer computer with 64bit Windows.
DarrenP
even if you download 2014 from the virtual agent you will still need a 2014 serial number which is not available under the student communtiy anymore
you need to look at upgrading to 64 bit
DarrenP
@Anonymous
You do not want to run Revit on a 32-bit system.  Upgrade your computer to 64-bit and thank yourself later.
