Revit 2014 Custom Block pattern Help
I have a special requirement for a CMU wall, with a 2"x6" stud wall.
I am building an exterior wall for a residential home model.
Brick exterior, basically is 3 1/2" width
1/2 mortar joints
I have attached a pic, of what the pattern should look like (created in msWord)
1/3 running bond, with 2 sizes of concrete block.
I saw somewhere on line, the program for the repeat, but am unable to find again
Michael - Toronto Canada
Alfredo_Medina
What is the repetitive pattern? Can you draw a rectangle over that image that defines what is repeated?
pattern as attached
Alfredo_Medina
Then, the pattern is this:
I would begin editing a surface pattern for masonry blocks, and figure out how to repeat one course, and add the addtional row. It might take some time to figure out the instructions, but it shouldn't be too difficult.
Other than that, you could try with Hatch22.
