Revit 2011 Rendering Issue
2 REPLIES 2
968 Views, 2 Replies
My Specs: Revit 2011 (update 2) Windows 7 64bit, 24gb ram
Issue: When i draw an object and then render it, no problem. When i try to edit the material, then render it again however, the object does not render at all. It is not even visible. Every time i try to edit the material, something seems to happen.
I open Revit 2010 models and wait for the upgrade process. Then when i render, only the RPC objects appear.
The same object is visible in realistic view with the correct material displayed. HELP!
Note: I used revit 2011 on my old computer (Vista 32bit, 4gb ram) and there was no problems. AUTODESK, WHAT IS GOING ON?
2 REPLIES 2
ryan.duell
Can you verify if the following process resolves the issue?  It sounds like the same issue:
http://revitclinic.typepad.com/my_weblog/2011/02/troubleshooting-elements-that-disappear-when-render...
Thank you,
Ryan Duell
step 1 resolved my issue.
