Revit 2011 compatibility with Windows 10
Is Revit 2011 compatible with Microsoft Windows 10?
This should not be as difficult to find out as this website apparently makes it.
If it is the 32bit version of 2011 the answer is no.  64bit, it might work...but you will probably have to uninstall a lot of Visual C++ apps.
Yes.
2-0-1-1?  Is this correct?
