Revit 2010
Revit 2010
ennujozlagam
Mentor Mentor
Revit 2010
ennujozlagam
Dear friends,
If my elevations views on the plans disappear/not shown, how im going to make it appear?
Thank you
LisaDrago
Can you post a little more info and/or an image?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
1st Thng I'd check is the VG  (view Graphics) for the view(s) in question.  The also check the view clip extents to make sure they are not outside the VC.
If  thsoe are okay, then please do as Lisa asked so we can see.
Mike
ennuj,
your question needs more detail. anyway, here's my answers:
A.  you or someone in your workgroup might have turned off the elevation tags category.  go to view graphics / annotations / check box for elevation
B.  you or someone did a "hide in view / elements" of the elevation tags.  do unhide elements
C. you or someone modified the crop view so that the elevation tags are now outside of the crop region.  to solve this, switch on crop view, stretch towards the missing elevation tags.
D. you or someone in the workgroup erased the elevation tags. if you have building elevations previously, just create new elevation views.
hope this helps.
edwin
ennujozlagam
Hi Arch. Edwin Yanga,
How are you my friend. Im was surprised that you are also a contributor in this discussion group. This site is a big help to the community using Revit especially for those begginer like me. I started using Revit 7 and until Revit 8.1 But sad to say i stop using Revit 8.1 because of our projects are more on Autocad. And now im trying to recall my Revit experienced But the problem, there are lot of new stuff in Revit 2010 which is new to me..
Anyways i managed to solved the problem and one more thing im only one working in the projects.
Thank you very much and to the rest of the contributor with a big heart to help in this site.
xie xie...
Thanks and Regards,
ennujozlagam
