Message 1 of 19
04:02 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Good afternoon, This is my first post here in this forum, so I hope I am doing everything right, although I am not sure if the following is an issue related to Revit or to the HP plotter drivers 😉 As the title says, we are currently still using Revit 2010 and we are having the problem that when printing e.g. a floor plan to a HP T1300 in a certain scale on a page that is bigger than the actual drawing size, the plotter spits out a whole bedsheet of paper. I know that in the HP settings one can check the "autorotate" and "eliminate blank areas" options and both are checked, so theoretically although I am printing on a bigger sheet, the plotter should take care of optimizing the printing area. But it does not, unless I am not seeing another option or tick that I have to check. By chance, anybody has run into this kind of problem? And knows how to solve it? Thanks in advance, Sebastian
