Announcements
Revit 14 linked file graphics column wall overlap
SPKM
SPKM
on my current project we don't have any structure modelled (inherited it this way) so everything comes from the struct engineers model, this causes lot's of graphic issues whereby columns i would normally join /cut walls i can't so visually i can see the overlap everywhere.. and it looks very untidy.
Does anyone have any suggestions on what can be done (except modeliing / copy monitoring in the structure? typical example below
undefined
Replies (9)
L.Maas
Alternative could be to use annotations (e.g. masking regions).
Or create a family with a region included
Or...talk to the structural engineers.
Best alterantive depends on the project. How many instances,  many changes to be expected, control over structural engineers etc.
Louis
Please mention Revit version, especially when uploading Revit files.
SPKM
the project to to large for a masking / annotation solution
so are you saying create a masking region in the column family at ref layer?
L.Maas
An example how I have used it before in a project.
Added a symbol family with a region (1) to the column family
undefined
Added a visbility control to enable hiding the symbol (2).
Further control can be created with the use of visibility settings (3).
Attached the project with the example column included.
Louis
rosskirby
This is a bug in 2014.  If you upgrade your project to 2015, it will go away, and the columns will, by default, overlap the wall, rather than the other way around.
I believe the bug originates when you attach a column top or bottom to a floor or roof system family, but after the error appears, there's no fixing it, and it becomes system (i.e. it affects more than just the column that had its top/bottom attached).
Sorry there's not a better solution.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
SPKM
thanks for the replies, i couldn't use the column attached as the project is in 2014, there are 28 architctural models in total so not an option to upgrade at the moment.. nevermind all the structural and mep model as well!
interesting that you say it's a bug, i hope it is a fix for 15 then
chrisplyler
Just as an aside, can you describe what coordination workflow requires twenty-eight architectural models? I'm awestruck.
SPKM
Downtown DOHA phase 4 - 14 buildings inc hotel / residential / commercial  (22 in total facade /core + interiors) + 6 level basement and Gold line metro box. split over 3 offices US + UAE + CAN..
SPKM
I may have to use this option, what did you do on 3 to change the visability settings.
when I load this column in to another file i can't see the mask, ticked or not ticked
undefined
L.Maas
I used the visibility settings in the family of the symbol
undefined
Louis
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
