Revision
Revision
Revision
Hello to everyone,
I am at the moment trying to modify the sheet template from my company and at the moment I am having some problem in making the review of the current drawing automatic. In my sheet, I am sharing part of the subtitle which I am creating, the revision is addressed by the name "REVISÃO", portuguese word to review, and as you can see in front of the review label there is an "exclamation mark". The parameter that the "exclamation mark" is refering to is the shared parameter "Current revision". As you can see throuhgt the picture the revison number that I have is the number zero, wasn´t it supposed to appear on the sheet the number zero, in substitution of the exclamation mark?
Best regards
Show in Revision Schedule checked?
But do you have any revision clouds on the sheet or in views of the sheet, or manually assigned to the Sheet like below?
@ToanDN: what screen capture/markup program do you use?
Mostly Windows Snipping tool.
Picpick when I need to capture floating dialog boxes (the ones that disappear when you click a mouse button).
Already working. Thanks a lot
