Revision schedule showing added row in sheet view
2 REPLIES 2
631 Views, 2 Replies
Hi all, I am having a problem when creating my revision schedules in a sheet family. After creating my schedule and getting rows and columns set up the way I like on my sheet template, I load the family into revit and add a floor plan view to it. Then when I go to view the sheet in the project I am left with an extra row at the top of my revision schedule that does not appear when I go back in to edit the Sheet in family editor. Have any of you experienced this problem and have recommendations to fix it? Attached is the view from when I am editing the sheet in family editor as well as a view from the sheet in the project. I am working in Revit 2018.3 Thanks. Robert
2 REPLIES 2
This setting work for you?
mark.ryanV3F5A
Hi @Anonymous ,
Thanks for posting on the forums.  I believe @barthbradley hit the nail on the head with the suggestion above.  If so, please click "Accept Solution".  If you need any additional assistance, I would be glad to help.
Best,
Mark
Mark Ryan
Technical Support Specialist
