Revision on Sheet
Revision on Sheet
Message 1 of 13
Revision on Sheet
Hello.
I have added a revision scheduled to my titleblock Coverage / Normal sheets. I have 30 odd sheets in my project.
When i go to revisions on sheet and tick the revisions shown they are only being displayed on the single sheet. Is there a way to have when I tick shown revisions on sheet they show on every sheet in the project?
Replies (12)
Message 2 of 13
Download this gem.
Message 3 of 13
Thank you will give this one a go!!
Message 4 of 13
Iv download it. just having issues trying to then add it as an addin to revit
Message 5 of 13
What is the issue?  Did you run the MSI installation file?
https://apps.autodesk.com/RVT/en/Detail/Index?id=5513670845846828779&appLang=en&os=Win32_64
Message 6 of 13
so i have installed it, then how do i add it into my add-ins on revit?
sorry never done this before trying to look on you tube how its done
Message 7 of 13
After install it you just need to open Revit and the app should list under Add-ins tab.
Message 8 of 13
Perfect, I have closed Revit and reopened it. It is there in Add-Ins. It is currently grayed out however. how do i activate it to then apply the changes to each sheet?
Thank You
Message 9 of 13
What is grayed out?  The UpRev button?  Do you see the below?  Did you open the Revit project file?
Message 10 of 13
I havent got the second box
Message 11 of 13
Maybe the App is not compatible with older versions of Revit. Too bad.
Message 12 of 13
bugger, thanks for your help
Message 13 of 13
Viveka_CD
Hi @Anonymous
Check this document for version history and to confirm the compatible versions, looks like Revit 2017 and up is supported.
You can also write to the manufacturer for further support. (support@xrev.com.au)
Let me check if there are any other add-ins available.
