Revision clouds size
gschwab6X3JN
Message 1 of 10
gschwab6X3JN
Is there any way to have different sized revision clouds in one model.
I have the need to use smaller arc sizes in different locations
Replies (9)
Message 2 of 10
The minimum arc length for the revision cloud shape can be specified in the Arc Length option on the Sheet Issues/Revisions dialog. This setting controls the arc length for all revision clouds in the project.
Message 3 of 10
Yes you can change the minimum arc length in the revision settings before you draw a revision. Or you can draw the cloud segments manually using line tool.
Message 4 of 10
gschwab6X3JN
Thank you, however what I need is to be able to have to different revision clouds that have different arc sizes in the same model without have to draw with line work.
Correct me if I am wrong, if I set the arc length here all the revision clouds will change when this is changed, therefore I cannot have two different size arc length in the same model.
[cid:image003.png@01D6CD78.D1A96EC0]
What I mean is on the titlesheet I need a small arc revision cloud
[cid:image005.png@01D6CD78.D1A96EC0]
Then on a plan sheet I need a larger arc revision cloud
[cid:image007.png@01D6CD78.D1A96EC0]
I am not able to find a way to do this without drawing them by hand.
Is this correct?
Message 5 of 10
Arc length should not affect clouds already drawn, only the one you are going to draw.
Message 6 of 10
I don't understand the "size" issue. Revision Clouds are Annotative Elements, like Text and dimensions.
Message 7 of 10
Baida.AboswilemWRYYU
Observer
Observer
Today I was looking at the same issue, and found this option that allow you to change the arc size. hope it helps.
Message 8 of 10
CADgrump
Thank you, Baida!   This helps, a lot.
Message 9 of 10
spkahle
Community Visitor
Community Visitor
Ahh, thank you! The View>Revisions>Arc Length was overriding my arc length adjustments within the Revision Cloud. Much appreciated.
Message 10 of 10
enawabi
THANKS
