Reversing surface normals
ind9
ind9
Hello, I have created a surface in Revit, but it appears that the surface normals are reversed from where I would like them to be. Is there a way to reverse the direction of the normals of my surface?
Lakshman01
@ind9 Can u pls attach your problem as a screenshot over here for to clearly understanding purposes? Behalf of your query i just giving you some suggestions as my point of view reg that surface direction,
1) Try to edit the surface grid's (U & V) direction to 0 deg to 180 deg.
or else
2)If its not worked out try to edit the type parameters / create the family parameters for that particular surfaces.
ind9
Thank you for the reply. The problem is occurring between two families I have created.  I created this "frame" to act like a framing system for a glass structure.  The problem is when I try to apply the "frame" to the surface I created the frame is inside out. I would like for the structure to be on the inside of the surface, but currently it will only be on the outside.
martijn_pater
Try creating form/surface with splines drawn in opposite direction.
RDAOU
@ind9
Why not flip the Pattern component?
