Reveals + Splitting Wall Surface
Message 1 of 23
I'm using a V-shaped reveal on the exterior of a precast panel. I would like the reveal to separate the exterior face of the wall so I can apply a paint pattern.
The project I'm referencing has reveals that separate the exterior faces of walls and I have no idea how. I even imported the reference project's reveal into my project and it still behaves differently.
Also, I do not want to use the "split face tool" to dissect the whole wall. I want the interior face to be one solid surface still.
Please let me know if you're aware of any tips or tricks.
Thanks!
Replies (22)
Message 2 of 23
Sahay_R
Two separate walls on top of each other. Place the reveal at the junction. Place a second wall on top of the first. Then join geometry, and it cuts itself out of the other field. Same number of lines as split face, or drafting it, and its a more stable result...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 3 of 23
cbcarch
You might also consider using Parts--take a look here:
http://www.aga-cad.com/blog/how-to-model-complex-precast-wall-panels-using-revit-parts
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 4 of 23
Can you post the file with the walls you want to replicate in your project. We can tell you exactly how they were built.
Message 5 of 23
I attached the reference project.
I just found out that the reference project used the "split-face with wall reveal" trick from this webpage: https://bimtionary.blogspot.com/2010/02/split-face-with-wall-reveal.html
I read the instructions but still do not understand how to make it work. "Create a tiny 1/16" x 1/16 wedge. Select Finish Sketch."
How do you create this wedge? The reference project has the split face away from the exterior wall surface. Also, you never "select finish" when using the Split-Face tool.
Message 6 of 23
cbcarch
Split with Gap?
Cliff B. Collins
Message 7 of 23
The reference project modeled the walls as pieces on the exterior for the panels and continuous walls for the interior.   What about it that you cannot replicate?
I would rather use a single wall, place V-shaped reveals, create parts from the wall, and split parts where the reveals are.  there you have more control over material options for different panels (parts) without messing up with split face and paint.
Message 8 of 23
Are you asking how to make a wall reveal?
A reveal has a 2D Profile Family associated with it. In the project you posted, the Wall Reveals are made using the "RPA Reveal - Concrete 1.5 Vee" family (located in your Project Browser under "Profiles"). If you want to use this Profile in your Project, then copy it over and assign it to your Wall Reveal Type.
When you select Wall:Reveal (under Walls on the Architectural Tab), the default Reveal Type will be shown in the Properties. That Reveal Type has a Profile Family assigned to it. You can check or change what Profile it's using through the "Profile" drop-down box located under its Type Properties.  The Reveal Type being used in the Project you posted, is named "Reveal - 1 1/2" Vee", which was likely made by duplicating and renaming the OOTB "Reveal".  You can name yours whatever you like, or not at all.
Message 9 of 23
Alright, I got it figured out!
I used the "Split-Face with Wall Reveal" trick as mentioned above with the link. My problem was that I confused "Split Face" with the "Split Element" tool.
Select a Wall > select "Split Face" (icon looks like a 90's computer screen) > go to a corner and draw a singular, diagonal line > select "Finish Edit Mode" (Screenshot attached)
Now, magically, the reveals separate the exterior face of the wall for materials to be applied.
Message 10 of 23
Unfortunately that blog post link no longer works. Any way you can give us the TL;DR (more like Can't Read)???
TIA!
Message 11 of 23
What do you mean by TL and DR? I'm not familiar with these abbreviations.
Message 12 of 23
Too Long, Didn't Read. Not exactly a fit for this situation as it's more like Can't Read, haha!. Also I have no idea how long the blog post was.
But what I'm looking for is the solution.
Message 13 of 23
Did you read message #9? I described the solution. Does it not make sense? I attached a screenshot too to help illustrate the explanation.
Message 14 of 23
No sorry, I didn't see that. There were several green solution boxes.
Thanks!
Message 15 of 23
No problem! Let me know if you still have troubles.
Message 16 of 23
Thank you very much!!!!!!!!
You saved me time!
Extremely strange solution - but that worked!
Thank you!
Message 17 of 23
RHWDesigns
That works, but it's very risky. Moving a window or shifting a wall could break the entire thing and nobody would know why.
Message 18 of 23
benhagerman
I believe this is issue was solved with the release of 2020.2 or earlier
Message 19 of 23
DwaneL-FGMA
I just tried in 2020.2 and it doesn't look like this has been fixed yet unfortunately.
Message 20 of 23
