I notice there are some shapes under Reveal and Sweeps under the Wall Buttom, and you can see the Default Shape notch and other brick void shapes that I can add to the building elevations without having to go to the wall sections for the sweeps, which is a laborious process.
My question is, the Profiles seen in the Edit Type dialog are limited and are not what I want to add to the exterior walls elevations. I can add the default shapes, but not what I need.
Under the Profiles of the Library Division Profiles, there are some V Shapes and another Tapered North Profile.rfa which are what I need. How can I add these to the list shown on the Edit Type dialog so these could be added quickly to the exterior elevations vertically and horizontally?
Thanks in advance.
