reveal profile
reveal profile
abdurrashad187
reveal profile
abdurrashad187
when i try to make profile by reveal in revit 2024 not show me reveal profile file in family.
alan.johnson7YLND
Sorry need a bit more information, as to you issue.
alan.johnson7YLND
Are you sure you loaded your profile in?
jay_colc
As a tip, always use an existing Profile from the Project Browser > right Click > Edit > Save As - and edit to your needs this will ensure if already works as expected and the Family Category and Parameters are setup correctly
Jay Colcombe
Autodesk Certified Instructor
Are you looking for the Profile Template (rft)?  See attached.
https://help.autodesk.com/view/RVTLT/2022/ENU/?guid=GUID-0814CCA3-8FE4-48E2-9A21-33BB9DAAEAD2
...or, are you trying to create a Reveal Type in the Project?  Profiles are pulled into the Reveal Type Properties.
handjonathan
Hi @abdurrashad187
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley @jay_colc helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
