Reveal on three side of the wall
i_hasib
i_hasib
Hello, i am trying to add reveal at three sides of an exterior exposed wall. But am only able to add on both exterior and interior. On the depth side ,i cannot add reveal. Is there a way!
You can modify the return of a reveal and turn it around the corner.  Look at the ribbon when you select a reveal.
syman2000
Alternative way is use linebase family void and then use cut tool to cut the wall from the line base void.
i_hasib
This option seems not working.
i_hasib
I was hoping for a reveal added to the wall structure and it will do the work. Cutting each element is a lot of work.
syman2000
If you don't like that, then use face base.
i_hasib
This does work. Thanks again.
