Retaining walls in Revit LT???
biztrobill
Message 1 of 14
biztrobill
Hi, All. I'm modeling terrain in LT and I need retaining walls. Pads won't do the job because I need warped surfaces on both sides of the retaining wall. I'm actually considering doing a 2d grading plan but that's gotta be a dead end idea. Any thots? Workarounds? Suggestions?
Bill Fowler NCARB
Revit LT Suite 2024
Mac M2 Pro Mini, Apple Studio Display; w/ macOS Ventura, Parallels 18, Windows 11. 32GB memory (Parallels assigns 16GB for Windows virtual machine)
Solo Architecture practice in residential and small commercial design.
Replies (13)
Message 2 of 14
Something like this?
Message 3 of 14
What do you mean by "warped surfaces"?
Message 4 of 14
Maybe you mean sloped terrain on both sides?
Message 5 of 14
biztrobill
Thanks, ToanDN.
Your illustration looks like it might be a pad, sloping in one direction, right? I'm trying to make a retaining wall that cuts the toposurface so I can slope each side of the wall independently and in more than one direction (warp). Screen clip attached.
Maybe there's a workaround, like splitting the surface or subregions?
Bill Fowler NCARB
Revit LT Suite 2024
Message 6 of 14
Message 7 of 14
biztrobill
Thanks, barthbradley. Actually I'm not looking for a wall shape. I'm looking for a way to use a retaining wall to let me define different 2-direction slopes on either side. It's a 3D problem. As I tried to explain, a pad won't work because it only slopes in one direction.
Bill Fowler NCARB
Revit LT Suite 2024
Message 8 of 14
It was a real retaining wall sitting on a pad.
Message 9 of 14
Both photos I posted are modeled.  As I showed, I used a SLOPED Building Pad which also inserts with it a Topo Infill which it cuts the Toposurface.  FWIW: This is how cut/fill computations are made in Revit -- from the Topo Infill; not from the Pad.
BTW, the Section Views (of the model) were done to show how I was interpreting a "warped surface".    I've never heard that term used in relationship to site work such as you are describing.
Message 10 of 14
Have you considered using two pads sloping in opposing directions.
You know you can "cut" the Toposurface yourself?  I mean, you don't need a pad to cut it.   If you know the elevations and/or slopes, it just a placing/removing points at the right locations.
Message 11 of 14
biztrobill
I might have figured it out. I used the Split Surface tool to define a rectangle for the area on the uphill side of my retaining wall, and then I deleted some of the points and placed new points to define the new spot elevations. The wall doesn't do the cutting, although that might be a nice feature. Screenshot attached.
Thanks for the help!
Bill Fowler NCARB
Revit LT Suite 2024
Message 12 of 14
Exactly!!!
Message 13 of 14
The retaining walls don't cut but you can draw a pad underneath the walls, same size as the walls, to cut the topo. Look at the picture I posted earlier.
Message 14 of 14
4 Building Pads.
