Resizing Brick
Resizing Brick
jgarciacorpus69
Message 1 of 18
Resizing Brick
jgarciacorpus69
Does anyone know how to make this brick sliding thinner?
Here on edit Assembly it is already thinnest to 0' 1" and it did not make the brick here shown on the picture thinner.
Replies (17)
Message 2 of 18
Edit Assembly?  How are you applying the brick?
Message 3 of 18
jgarciacorpus69
It was already there when I was given the model to work on, and they want it the brick band to be thinner but I do not know since I have tried to change the thickness of the brick which I did here on the picture shown. I changed to the thinnest it did not change that.
Message 4 of 18
That screenshot doesn't relate.  Select the brick (or bricks) and tell me what it says under Properties.
Message 5 of 18
jgarciacorpus69
Message 6 of 18
Aren't you talking about the brick row?
These:
Message 7 of 18
jgarciacorpus69
Yes the brick part that is in the middle of the wall. I want to know how to change the width of that. Because it is too thick right now.
Message 8 of 18
Edit the Wall Assembly and edit the embed Wall Sweep profile.  If it is from a Split Region then edit the thickness of the layer assigned to that region.
Message 9 of 18
jgarciacorpus69
Where do I click I am confused where does it show the thickness for the brick?
Message 10 of 18
You need to modify the thickness of the PROFILE.
Message 11 of 18
jgarciacorpus69
I do not see the thickness, I only see -0' 8" is that the thickness I edit?
Message 12 of 18
jgarciacorpus69
Mine does not show like that.
Message 13 of 18
 Find the Brick Profile Family in your Project Browser and edit its Type Properties.
Message 14 of 18
jgarciacorpus69
I am there I clicked it but nothing happened, but when I go to properties it does not go to Wall Sweep-Brick Soldier Course: 1 Brick
Message 15 of 18
jgarciacorpus69
When I go back to Type Properties it does show like the one on shown on Wall Sweeps
Message 16 of 18
jgarciacorpus69
I went to the project browser, I do not see the Wall Sweep-Brick Soldier Course just system family: Basic Wall, Curtain Wall, Stacked Wall. How do you get the Wall Sweep Brick Soldier Course ?
Message 17 of 18
mhiserZFHXS
You have to look under profiles... not walls...
Message 18 of 18
jgarciacorpus69
Oh okay, now I understand. I had to go project browser, go to families, go to profiles and then look for that file and click on it and then change its dimensions of it there.
