Resizing automatically an image into a Revit family
Message 1 of 9
Hello everybody,
I would like to create a Revit family (Generic annotation family for example) and get an image. But when i get the image into the family i would like to automatically resize it. For example give a maximum height or a maximum width to it, with a shared parameter and a linear dimension for example...
After several tries and research, i didn't find a way to do this.
Does anyone have an idea or a solution?
Does anyone create this before?
Sincerely,
Romain,
HVAC Engineer and BIM Coordinator
Replies (8)
Message 2 of 9
L.Maas
If you have loaded an image into your family and you select that image then you can see it has a width and a height. You can set a parameter for these in your family allowing you to change height and/or width.
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 9
Yes Louis, I agree, but I would like to give a maximum width or height, because the available space into the title block will be always the same. So to avoid to resize manually each image of each different projects I would like that the Revit family resize the image automatically with maybe a shared parameter and a linear dimension
Message 4 of 9
mbhame
 Was any resolution found to this question? I think we are experiencing a similar situation.
TY
Message 5 of 9
Unfortunatelly I never found how to do this... Did you get what you wanted to do?
Message 6 of 9
martijn_pater
So, you want to apply dimensions to the nested annotation family image based on a value(range) from a main family parameter?
I think you could probably just use an IF formula like IF(imageheight>(insert maximum titleblock height), (insert maximum titleblock height), imageheight) and then return a imageheight_calculated parameter ? Not sure what you're after...
(Also you might want to nest the image annotation family twice for position control.)
Message 7 of 9
yes that's exactly what I'm looking for. I'm going to try your solution. I was thinking also about aligning edges of the image to the borders of a square/rectangle (design with 4 lines), block edges with lines, and put cotations (lenght and width) but I don't know if it's possible
thank you
Message 8 of 9
I don't understand the struggle of just typing a single value to change the image dimension. Instead, you want to go through the hoop of creating parameters, a formula to control a parameter based on other parameters, then assign the controlled parameter to the image?
Message 9 of 9
martijn_pater
Well, I figured the question was to automatically have an image display in a certain way in some title blocks or something. But you are right ofcourse, you could just add some type parameters for the image dimensions and have it adjust to that.
