Resize Row on Schedule in Revit
Hi There
Does anyone know a way to resize rows in Schedules?  I created a room schedule and it creates as per the visual.
I understand that row height is dictated by Text, however, I cannot even read the text on mine.
Thank you!
ennujozlagam
@Anonymous hello you may try to check it HERE . thanks
What is the resolution of your monitor?
Not using a Monitor - using a MacBook Pro with dual operating operations.  I think the answer above should solve.  Just need to double check later.
Hi, I'm running into the same issue with the row height in Edit Schedule. I could barely see the text. I attempted to follow the previous solution, but I didn't have any image inserted into my schedule. Any suggestion? I'm running a Mac Book Pro with Windows 10.
