Request for save option to older version in revit
vishnurmdy
vishnurmdy
I just tried using revit from older versions in my coaching class but some of the computer there has older or newer versions 🤔
Because of that my friends can't share the file feom one system to another , I would be great if the developers could make options to save in older versions  has if we convert to IFC FORMAT some model components change we are unable to see any parameters after conversion to IFC FORMAT
So I'm requesting that is there any possibility of getting update regarding this in any upcoming versions 🤔
RobDraw
That will never happen. It's been made clear from the beginning but you can try posting in the IDEAS forum.
You do know that you have access to multiple versions with your license, right?
Rob
HVAC-Novice
You'll need to coordinate with your peers what version you use.
Backwards compatibility is not possible.  It is not a conspiracy
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
This has been explained multiple times on this forum
Search this forum
