Represent box jacking on Revit building phases
amoravek
amoravek
I'm doing an underpass project that needs to be pushed under an existing train sation. My problem is that i don't know how to change the position of the underpass which is built in an initial position and then is pushed under the railway. How could i do that?
Thank You.
Tom_Kunsman
Your question is a little confusing, but it seems like you are asking how to show/model a clearance zone so you know how much the underpass needs to get raised.
So I would use a Clearance Zone family. There are several YouTube and web results that show you how to make your own.
Mike.FORM
Have the underpass modeled in a separate model and then link it into the existing train station model.
You can then place the underpass link instance multiple times in different places and using phasing you could show it moving under the station in phases.
I don't understand your dilemma.  If you're wanting to model a structure below another existing structure, then add forward Phases of construction and additional Levels under the Levels that carry the existing structure.
amoravek
Hi, in this video is what i want to represent in the different building phases.
https://www.youtube.com/watch?v=VaDnkO3suQM
Yes, I fully understand, and I explained (with screenshots!) how to get there in my post above.  Did you read it?
