A quick question, is there a way to rearrange family parameter as we want as I have more than 50 parameter need to be move accordingly.
Yes there is, if you mean the order they display in.
Go to family types, use the light blue arrows to arange to your likeing, or sort alfabaticly.
Some additions to @benschilders answer.
Typically when you once loaded in a family with a certain parameter order, Revit tends to remember that. So when you change the order in the family editor and reload it back in the project, you have a good chance it will not change the order in the project.
You might need to start with a clean project for this to happen. It also might mean you need to rebuild your project templates (depending what you have loaded in there).
I have not checked if this behaviour has changed in recent versions of Revit.
Louis
Please mention Revit version, especially when uploading Revit files.
Louis
I think those two are the only batch sorting options.
Maybe somebody else knows antother way, myself i am happy that we even get the option to
sort the parameters order 🙂 (although i understand that sorting 50 parameters is not fun...)
If you look at my previous post, you might conclude from this that you do not need it to change for families.
Once a family has been loaded into the project it keeps that order.
Otherwise you might be able to do something with Dynamo.
Louis
Louis
@L.Maas i think he could try to save the family as another version like ad v2.0 in the name or something.
And then load the family into the project, this way Revit sees it as a new family.
Then use select all instances to replace the original family with the new V2.0 one.
I think this might work.
