RENDERING
RENDERING
RENDERING
Good morning,
Could someone render the file I attached?
And If it could possible, If you could explain how did you render it I would thank you.
Thanks for your help.
Regards.
aRcHiTeCt.JM
... this is a .dwg file
.... in here we work with .rvt files
.... do you want to learn how to render in REVIT ?
.... first you need to make your project in REVIT
..... and at the end of that you can render in REVIT projects like these:
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
In my case I design with Advance Steel (AutoCAD 3D) and then I try to render it with Revit. But I don´t know how to render with Revit.
Yes, I want to learn how to render with Revit.
aRcHiTeCt.JM
... I can not open the .dwg that you uploaded
... it's empty
aRcHiTeCt.JM
REVIT EXPERT ELITE
You attached the wrong file, or you are on the wrong forum, buddy.  This is a Revit Forum.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoC...
