Rendering
Rendering
Rendering
Could anyone help me with rendering in 2014 version?
Please see the picture attached. It is only a draft one so the quality is quite bad but my issue is the lighting.
The Intensity is right and I don't know why I have those black spots.
Hello.
It seems to me that those are spaces above the lightning fixtures which are offside the light region.
Inside those lightning fixtures families probably you`re gonna see the lightning origin, an yellow symbol. If you select these symbol, you can define the origin of the light and the type of light direction (spherical, hemispherical, dot etc).
So, those black spaces on your model only gonna be lightned if these region reaches there.
If your problem has been solved, please click on Accept as Solution. Then others users can take benefit of it.
Felipe Góes
Autodesk Instructor
Thank you. It was the light direction.
Your're welcome!
Felipe Góes
Autodesk Instructor
