Rendering
Rendering
mrheuseler
Rendering
mrheuseler
I'm trying to render directly in Revit.
Normally I use Twinmotion, but in fact that I need my background to be transparent, Twinmotion is not an option.
However, I think my "sun settings" is really bad. And I can not control them.
Please see my picture attacthed. How do I render so I can not see the "blue sky" in the glass reflection?
Just want to see the same color all over the glass - with transparent background.
How do you render perfectly with no sun - just the colors?
I'm going crazy! 🙂
Thank you.
Kind Rergards
Morten, Construction Architect.
cbcarch
The results are as expected, since the render engine is raytracing and using sunlight and reflections on the glazing.
But if you don't want the sky reflections ( not sure why?) You could try adjusting/reducing the reflective quality of the glass material.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
cbcarch
You might be able to use a custom background image that is set to White? Not sure about results as I have never tried it.
Cliff B. Collins
Try Advanced Render Quality Setting...
