Rendering
3 REPLIES 3
mrheuseler
245 Views, 3 Replies
Rendering
mrheuseler
I'm trying to render directly in Revit.
Normally I use Twinmotion, but in fact that I need my background to be transparent, Twinmotion is not an option.
However, I think my "sun settings" is really bad. And I can not control them.
Please see my picture attacthed. How do I render so I can not see the "blue sky" in the glass reflection?
Just want to see the same color all over the glass - with transparent background.
How do you render perfectly with no sun - just the colors?
I'm going crazy! 🙂
Thank you.
Kind Rergards
Morten, Construction Architect.
Rendering
I'm going crazy! 🙂
Thank you.
Kind Rergards
3 REPLIES 3
cbcarch
in reply to: mrheuseler
cbcarch
The results are as expected, since the render engine is raytracing and using sunlight and reflections on the glazing.
But if you don't want the sky reflections ( not sure why?) You could try adjusting/reducing the reflective quality of the glass material.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Cliff B. Collins
cbcarch
in reply to: cbcarch
cbcarch
You might be able to use a custom background image that is set to White? Not sure about results as I have never tried it.
Cliff B. Collins
Cliff B. Collins
Try Advanced Render Quality Setting...
