& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I am having an issue with rendering. I keep getting these grey patches on the desk front. I have re-modeled it, changed the material, created a new material, updated my graphics card, rendered in the cloud, restarted my computer, and nothing helped. I am using Revit 2022.
What about more Rendering Time? Does it improve?
Also, screenshot us your Rendering Settings.
If that's maximum, then forget about time. Try another Material. Use one of the PBR Assets.
Could be any number of things. Post the file. Lets take a look at it. Tell us what version of Revit you are using too.
You didn't by any chance model thin wood veneer? That would explain it.
Increase the veneer's thickness, or get rid of it and instead paint the surface that the veneer is on top of with the veneer's material.
I notice if you have wood veneer thickness of 1/16" or 1.5mm and surface is curve, you will encounter these overlapping material. So try to make the whole material the same or you make the wood veneer thicker than 1/16" (1.5mm).
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
