Rendering with a pure white background
lebelKQRXV
Message 1 of 20
lebelKQRXV
I am building a furniture library and need each piece on a solid white background. I need them rendered and photograph quality.
I cannot figure out how to make a pure white background. Everything looks brown or the sky blue of the environment. Even a white room doesn't looks white.
What is the trick?
Replies (19)
Message 2 of 20
constantin.stroescu
You can obtain this if :
  • in Project, from View Control Bar >Isolate Element ( the Piece of furniture)
  • when Rendering > Background >Style > Color - White
Constantin Stroescu
Message 3 of 20
constantin.stroescu
if you want the shadows too,
then:
  • Copy to Clipboard the Isolated item
  • Paste it into a New Project
  • in the New Project , make a white material floor
  • render with White Color Background and then use Adjust Exposure to assure the background is pure white
Constantin Stroescu
Message 4 of 20
lebelKQRXV
I tried this. I made a white material floor and white background and it renders grayish brown. The sunlight changes the white. I've tried adjusting it and it is always not white.
Message 5 of 20
constantin.stroescu
try a refine of White Point....
Constantin Stroescu
Message 6 of 20
Is there any way to do that when rendering with Vray.I can't seem to find any option to change the background color while rendering in revit.
Message 7 of 20
Viveka_CD
Hi @Anonymous
I wanted to follow up on this post.
Can you send a screenshot of your render settings and share the model if possible?
I can send you a private folder if you like. You can also contact v-ray for Revit support team HERE
Looking forward to your reply update.
Message 8 of 20
lebelKQRXV
hello,
I am revisiting this 2 years later as I still have not found a way to do with without photo shopping the background white which always looks off.
Where do I find this "isolate Element" I go under "view"?  and do not see anything like that.
I have a white color background set and it is just never white. Is it the lighting settings or what? Trying to find the trick as I see these types of renderings used everywhere.
Message 9 of 20
Viveka_CD
@lebelKQRXV Can you please post a screenshot or screencast of what you are seeing?
it will help us troubleshoot better.
Message 10 of 20
aRcHiTeCt.JM
... open a project
... insert your family
... open 3d view
.... open graphic display options
... choose what you want to show
.... and .... pure white
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
Message 11 of 20
lebelKQRXV
I have already done that. It doesn't show as pure white.
Message 12 of 20
aRcHiTeCt.JM
... and with this?
.... to me looks like really white
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 13 of 20
lebelKQRXV
This does not look like a rendering. It looks like a shaded view and is not the look and quality I am trying to achieve.
When I put the table not in an environment within the project,  with an "image" set as a pure white color and render I get the attached image (1)and it looks awful. Looks cartoony and the materials and colors are off. That is supposed to be chrome. It messes up the lighting.
When I have it in a "room" walls and floors set to white and I have the "background" set to white it gives me gray. Image (2)
When I use the "transparent" background, it looks the same and I am not sure the benefit- ie my other question.
Message 14 of 20
aRcHiTeCt.JM
.... how about this:
.... or this:
aRcHiTeCt.JM
REVIT EXPERT ELITE
Message 15 of 20
lebelKQRXV
Again, that is not at all the look I am going for. I need photo realistic and less shadow. The materials and metals need to look real. I have messed around with those settings and it has not helped achieve my goals.
Message 16 of 20
lebelKQRXV
I Attached the finished renderings in the other post as examples.
This is a screenshot of the settings. The table is on the "floor" that is set as "white" .
Let me know if you have other questions.
Thank you,
Message 17 of 20
Viveka_CD
Hi @lebelKQRXV
Thanks for sharing the screenshot, can you also share the model to test.
I'll do some testing on my end for a different model and see if there is anything different we can try to achieve the required result.
Message 18 of 20
lebelKQRXV
Yes. i wish I was using one for the testing that had more interesting and brighter colors but for comparison it is attached.
Message 19 of 20
loboarch
I am not sure you are going to get a pure "white" background without using photoshop. That is just not how rendering works.You are going to end up with things being slightly "off" because the light is hitting at a different angel, something is slightly shaded etc... Getting everything except the object to be pure white is not possible. At least with the controls for rendering in Revit.
It kind of reminds of this old image (perhaps you have seen it?), "color" can be very deceiving both the squares in this image are the exact shade of gray, even though one looks really white.  If you want to see, just cover up the joint between the 2 on the screen with your finger.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 20 of 20
aRcHiTeCt.JM
..... go photoshop (best option)
... if I go whiter with REVIT the image gets cloudy
aRcHiTeCt.JM
REVIT EXPERT ELITE
