RENDERING NOT LOOKING REAL
WHY THE RENDERING DOES NOT LOOK REAL? I SAW A COUPLE OF REVIT RENDERINGS VERY IMPRESSIVE, OR THEY THEY ARE MADE WITH 3DS MAX?
ALSO IM SHOWING A LOT OF CURTAIN WALLS IN THE FRONT ELEVATION BUT THEY RENDERED WITH FILLED SOLID MATERIAL? THEY ARE GLASSrenderingrenderingprojectproject
Accepted solutions (3)
aRcHiTeCt.JM
… hi @Anonymous
… to get to a nice and good render you have to be patient
… you need to tweak your environment lights, artificial and sun and a lot of detail
… take a look into these links, they will explain how to do it
…. https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
… do you mind uploading the .rvt file to take a look?
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
aRcHiTeCt.JM
@Anonymous
… take a look at his exterior render filled with entourage, lights, all kinds of elements
... with a couple of more elements you will get a better more real result
aRcHiTeCt.JM
REVIT EXPERT ELITE
thanks, but why they show as a solid elements?
aRcHiTeCt.JM
... can you please upload your .rvt file?
.... it looks like those are showing some kind of reflection
... do you have an image from that rendered at BEST ?
aRcHiTeCt.JM
REVIT EXPERT ELITE
thanks. I will try to render it in best quality.
No, I can't upload the project file
