Yesterday I rendered my floor plan before leaving I saved everything. Today when I open the file and look at the floor plan, perspectives etc. in realistic view I see no color except the gray it originally starts with, however when I click on an item to see if the material is still on that item its their just not showing in plan veiws. How do I fix that?
Hi @Anonymous,
This looks like a Revit modeling issue, I would like to move it to
Revit forum for there may many experts could be helpful.
Check Phase Filter of the View(s). Try setting to Show Complete.
Keep in mind that your material 'graphic' has nothing to do with your material 'apperance'.
Plans will show graphic, but renders use the appearance, so make sure you are looking at your Revit material Appearance in the materials, not the Graphics.
To verify and troubleshoot this, jut set the view to 'Realistic'. It will show the material's Appearance.
