Rendering in Revit
Rendering in Revit
tonymacha
Rendering in Revit
tonymacha
Hi guys,
Is there a maximum number of times that one can render in a project?
I just realized that after 25 times i cant render anymore.
FGPerraudin
Hi Tony,
No there is no limit...
But if it is about online rendering (cloud rendering), you are limited by your amount of cloud credits... low quality renderings are free but higher quality cost credits...
And they give you a certain amount to start with, so maybe you didn't give it much attention...?
Is it about cloud rendering or standalone rendering?
François
Francois-Gabriel Perraudin
BIM management and coaching
tonymacha
This is standalone rendering not cloud
FGPerraudin
Does it give you any error message?
Stupid question, but did you turn it off and on again?
tonymacha
There is no error message. The render function is just not available
FGPerraudin
This is very weird.
First, check that you are on the right view, click within the view if necessary but I guess you have already tried that...
Second, try duplicating your view.
To me, Revit doesn't identify it as a "renderable" view and duplicating it should solve the problem.
Same if there was a count of the nimber of renderings, it should solve that....
Does it work?
