Rendering in Revit - Circles Appear as Polygons, But Only in Imported Families
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to render small details in Revit, and I am experiencing an issue where small curved faces render as polygons. However, this behavior seems to only occur when the small curved faces exist as part of an imported family. When I model-in-place an even smaller element, the render achieves the appropriate curvature.
Two images are attached for reference - the first shows a non-render screenshot depicting a modeled-in-place cylinder (left) and a family with a hole cutout (right). Both are of the variety "specialty equipment." In this image, both features appear with the appropriate level of detail. The second image is a render of the same view, but in this render, the cylinder face remains curved as desired, while the family with the hole cutout becomes polygonal. This behavior is curious to me, and I cannot determine what is causing the discrepancy.
What could be causing this behavior, and how can I render a small family with the desired level of detail in the curved faces? This is a simple example to illustrate the problem, so while I could use a workaround and model the entire family in-place, I would like to understand how to avoid this in the future.
Thank you for your time!
EDIT: I have discovered the difference between the family and the model-in-place geometry. When a cylinder is extruded from a circular profile, it maintains its curved faces when rendered. However, if this same cylinder is created from a revolved rectangle, it will render as a series of polygons. Why is this the case, and how can I make revolved shapes render as smooth curves?
