Rendering in Revit 2017
Hi so I'm trying to create a high quality render but everytime I do I get multiple blocks that are blurry when I zoom in. I have attached an image. How do I create a single high quality image?
Hi Rebecca,
To be honest, I've never seen that before. are you just using the standard render tool in Revit i.e.  no plugin?
Have you tried using the cloud rendering option?
Also is your Revit 2017 up-to-date? (2017.2)
what happens if you try to render a different camera view?
Just as an after thought...check you lighting setup in the render dialog....it's nothing to do with trying to render a multi-day or time is it?
