Rendered Camera Views- Versions do not align
I have a camera view set up and locked for a rendering presentation. There are two versions of cabinetry for the same view, so I have the cabinetry on work sets that I turn off and on for each render. The problem is, even though I am using the same view, the geometry is not lining up between renders. This seems to happen on and off- if I render them both in the same session they tend to align, but if they are rendered days apart they seem to change. It appears to be both the alignment and a slight scale difference. This is causing a lot of problems with design changes and coordinating post-production so I could really use a fix. I never had this problem with 2015 so it seems to me that it's a problem with the new software.
Could we perhaps get a before/after image of the views and also what version of Revit are you having the issues with? 2017? Have you applied the most recent Service Packs?
Can you duplicate the view and have one view with Type A cabinetry and the other view with Type B Cabinetry instead of alternating worksets on a single view? Does this correct the issue?
