RENDER IMAGE
RENDER IMAGE
Message 1 of 17
RENDER IMAGE
Could you help me, why lines in rendering image are not round and smooth like in project?
Render is good quality. Element is made with revolve tool.
Thank you
Replies (16)
Message 2 of 17
Bertievz
Have you tried to set the FACETRES variable to a higher value? At 0.5 mine renders with smooth edges.
Message 3 of 17
Where can I set it up?
Message 4 of 17
Bertievz
So sorry, I was wrong there, FACETRES is an AutoCAD setting. I don't think it is available in Revit. Are you using the Autodesk Raytracer or Nvidia mental ray renderer?
Message 5 of 17
I tried both and I even tried to render in A360 rendering, it is the same everywhere.
Message 6 of 17
ennujozlagam
@Anonymous hello, can you post the files and i will try to render if still the same outcome. thanks
Message 7 of 17
I attached it.
Message 8 of 17
I attached it.
Message 9 of 17
ennujozlagam
@Anonymous hello, if i'm not mistaken you already posted this before? thanks
Message 10 of 17
Yes I did, but no one could help. They even wrote me from the Autodesk Product Support Team and the man name Jacob said they were investigating, but I still didn't get no answer for almost 3 months now.
Message 11 of 17
ennujozlagam
@Anonymous hello, i tried to render in Revit but the outcome is the same what you have. you need to apply materials in your object and tick use render appearance  i try to export to FBX (tick : use lod / without boundary edge. open in showcase 2017 and render from there but didn't finish rendering just to show you the outcome, no more edge. please see attached. thanks
Message 12 of 17
ennujozlagam
@Anonymous hello just 25% render time and see the results, hope it helps. thanks
Message 13 of 17
This is a good idea! We have the showcase 2017 programe but really we dont use it. It works great. Thank you.
Do you think the programe is good for rendering houses and other objects?
Message 14 of 17
ennujozlagam
@Anonymous yes you can try. i used this software for my rendering and animation. no worries glad to help. thanks
Message 15 of 17
Do you know maybe what is the difference between 3d max? I can see the Showcase is much easier to use.
Message 16 of 17
ennujozlagam
@Anonymous hello, they have a different platform, there is a advantage and disadvantage so it's up to the user's to decide. you give it a try and you tell me. thanks
Message 17 of 17
You helped a lot. THANK YOU!
