Render a 2D dwg elevation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello:
I’m an architect by trade, working as a project manager at a hospital in IL. I do side work for an architect friend of mine, drawing plans and elevations for some of his residential projects Most are what would be considered McMansions, with detailed elevations and complicated roof lines. Because of this, I’ve only used AutoCAD for plans and elevations with a few interior perspectives in Revit (I import the DWG file and create various views and then render).
What I would also like to do is exterior renderings but, because I’m not creating the project in Revit or as solids in AutoCAD, I only have two dimensions.
Does AutoDesk offer a product that would allow for, or does someone know one that exists, where I can take a 2D DWG file of an elevation, import it and render with texture maps? I’ve tried it in Revit but have run into issues with perspective; I imported the dwg file, created a 3D view (by rotating the 2D elevation so the camera is pointing at it) and created model faces with attached materials. The one big problem I have is, if the roof slopes away from the view, for example, the shingles should get smaller. But I have no way in Revit to create the material as a perspective, all shingles are the same size, from the bottom of the roof to the top.
Does AutoDesk offer software that would allow me to apply materials to a solid surface and apply materials that can be manipulated (such as revising them to appear they're in perspective) without having the create a model of the project?
I want to render a 2D elevation to make it appear (however slight) it's a 3D elevation. Is Photoshop maybe my only option, or do I need to create a model in Revit?
Thank you for any info you can provide.
Joe
